compnent vs. s-video...any difference???
Discussion in 'Archived Threads 2001-2004' started by Damien, Nov 9, 2002.
  1. Damien
    Damien Supporting Actor
    Mar 29, 2002
    508
    i have a tv with 1 s and one component video input. i have the xbox connected via s-video, and my dvd via component. i only watch my dvd player VERY SPARANGILY, so I wonder if it's worth getting the hd pack. Will I see a big difference. I do notice that when i watch IGN's movies, when they use there in house tv, the same games they have that I also have look considerably more clearer than mine does.(i have a toshiba 20AF42)
  2. Jeff Kleist
    Dec 4, 1999
    11,267
    Damien, they're using specialized gear and video capture cards for their screen captures, not photographing their TV.
    If you TV is not HD, or can't at least do 480p, don't bother getting the HD pack
  3. Andre F
    Andre F Screenwriter
    Dec 9, 2000
    1,486
    2
    I'd say that you will see a difference, but I'm not so sure it will be earth shattering. Some people see a big improvement others don't. I'm in the same situation as you I have one component input but movies come first for me so the DVD player gets the input...
  4. RANDY FISHER
    RANDY FISHER Second Unit
    Sep 1, 1998
    285
    Damien, I have that same TV and use it for my Xbox, Gamecube and PS2 in my computer room. The answer for me is YES, get the HD pack. I am using a couple of cheap mechanical A/V switchers (one for audio and one for the 3 component leads) and I am running all (3) of my systems in component 480i. The aparent sharpness and color resolution of component video (even though not progressive) makes a huge difference to my eyes over s-video. Once I saw it there was no going back. I have a 36" Hi-def Sony XBR set I use right now exclusively for movie's so I don't game on it.
    Randy[​IMG]
  5. Morgan Jolley
    Morgan Jolley Lead Actor
    Oct 16, 2000
    8,818
    122
    9,110
    Get the HD pack. If it doesn't make a difference then either bring it back to the store or sell it. Most likely you'll be keeping it.
    BTW, this technically should be VG Hardware.
  6. Scott Simonian
    Scott Simonian Screenwriter
    Jun 20, 2001
    1,281
    The difference can be subtle to some. It depends on your knowledge of video I guess. The biggest difference comes in color fidelity thanks to the much higher chroma signal. Same goes for the luminance(sp).
  7. RayKk
    RayKk Stunt Coordinator
    May 4, 2002
    113
    IM using a HD pack for my Xbox and Sony XBR HDTV and there is a noticeable difference from S-video, if you have a HDTV go for it you will eventually need it when games become 480p and above.
  8. Michael St. Clair
    May 3, 1999
    6,001
    I'll be the lone dissenter.
    On a 20" interlaced set, you aren't going to notice a hell of a lot of difference between s-vid and component with video games.
    Save that component input for your DVD player and hook up the XBox via s-vid.
  9. Mike Pattee
    Mike Pattee Second Unit
    Aug 22, 2001
    317
    Should I bother with component on my ps2? I have a 46" mits I'm using s-video now. I'm using component on my dvd and xbox but I have another input.
  10. Donnie Seals
    Donnie Seals Agent
    Jul 20, 2002
    45
    Where can you get a HD pack? What does it come with?
  11. Joe Szott
    Joe Szott Screenwriter
    Feb 22, 2002
    1,962
    damien,
    What size is your set and is it HDTV compatible?
    I have a 46" Mitsubishi HDTV and the difference from 480i to 480p is very noticable. If you have a 27" non-HDTV, you probabyl wouldn't see any difference at all.
