John D S
- Feb 2, 2002
I have a 25 x 17 x 9' ceiling. Going to use single 1/2 inch sheetrock an all walls. Speakers are Martin Logan Odyssey,theater center and script rears. I have concrete floor and was originally planning on a plush carpet with thick padding but found some commercial grade carpet I like better but don't know if it will absorb enough to help deaden the room. The commercial grade carpet is very thin and dense and designed to be glued directly to the floor bu they can add a 3/8" pad.
2nd question: I have 2x6 walls all the way around. On one of the 25' walls I am insulating with 3" soundproof insulation plus 3" of regular insulation. The other 25' wall is already built with regular insulation only and sheetrocked. This is an outside wall that is on a foundation which sticks out 2" so I will need to fir it out with 2"x2" studs. Would you just sheetrock over this making it hollow for 2" or would you add some insulation to try and make it as close to the
same construction as the opposite wall. i don't know if it really matters or if I am just being too critical.
