Comments on Tempest sealed Mid or High Q Alignment?
Discussion in 'Archived Threads 2001-2004' started by Darren_T, Jul 13, 2002.
  1. Darren_T
    Darren_T Second Unit
    Oct 1, 2001
    494
    Hi,
    My Tempest is sounding better and better as I listen to it. My wife isn't really happy with the large box though. I may have to consider going with a sealed alignment mid or high Q for size. I'd like to hear from those who have built one of these alignments.
    How is the low extension...I know it won't be like the vented alignment but how low will it hit? I'm about 75% home theater listening and the High Q seems to be quite nice for that.
    Could some of you wise people tell me a little about what I will be missing and/or gaining as far as performance? I'm learning slowly!
    I'd calculate the performance myself but I'm not very well versed in that area of speaker design...I'm more of a "give me the plans and I'll build it" kind of guy but I really want to learn.
    Darren
  2. Pete Mazz
    Pete Mazz Supporting Actor
    May 17, 2000
    761
    What size box can she live with?
    You could still do a vented alignment in as little as 6-7 cu ft.
    I had a Tempest in a .7Q sealed alignment (~4 cu ft) and it sounded great, especially for music. Room gain makes up for some low end but not what you're getting now. Figure it'll be 10 dB down at 20 Hz....maybe down 4-5 dB with room gain.
    Pete
  3. Griff
    Griff Stunt Coordinator
    Jul 6, 2002
    53
    For a small cabinet, try and get an amp with built in boost of 10-12dB at 10Hz, it will make all the difference.
  4. Manuel Delaflor
    Manuel Delaflor Supporting Actor
    May 25, 2001
    657
    Griff
    Is there a way to calculate the precise dB's and frequency in order to, say, get the F3 at 20Hz using a small cabinet?
  5. Griff
    Jul 6, 2002
    53
    hmmm, not that i know of. Ill do some research and get back to you.
