James*S*G
- Oct 13, 2002
I'm looking to make a surround sound purchase in the next week or so.
I have listened to a variety of speakers and receivers. I narrowed it down to PSB Image series (FrL/R:4T, C:8C, RrL/R:2B, Sub: Sub5) and the Paradigm Monitor series (FrL/R:7's, C:CC370, RrL/R:Mini's, Sub: PS1000). I wanted towers for the fronts due to younger children in the family and my wife's view on esthetics.
The room they are going into is the main floor family room (13'x17' with a 9' ceiling) with the shorter distance between the front and rear walls. The viewing/listening area is 13'x13' due to a doorway on the front wall and a fireplace on the sidewall abutting the doorway.
I was going to match the speakers up with either a Yamaha RX-V1300 or a Pioneer Elite VSX-41TX and a Toshiba DVD player SD4800. With both receivers, I intend to run in 5.1 at this stage.
The system will be used for music and ht.
I prefer the Monitor series but also found few faults with the Image series.
Does anyone have a similar Paradigm config?
I've seen comments about the PS-1000/1200 subs and some preference for the PW-2200. I know on the Paradigm site, they include the PW-2200 in a config with the Monitor 7's. So I'm wondering if that should be considered?
I've had conflicting advice on Surrounds on stands (dipoles vs directional - single tweeter/single driver). My room has a bank of four windows on one side wall and a fireplace on the other one? There are too large openings on the front wall - one for a large floor to ceiling dooway and the other a large opening to the kitchen. To get a directional speaker in the right position I'd have to put it on a stand which I'm comfortable with. Do people put surrounds on stands? I'd be willing to mount them on the rear wall but have been told I'd lose much of their value due to the windows on one side and the large openings on the front wall.
James
James
