Comcast - i dont need tuner right?
Discussion in 'Displays' started by andrewPeterson, Sep 9, 2005.
  1. andrewPeterson
    andrewPeterson Auditioning
    May 6, 2005
    7
    I am moving into a place which has comcast.
    I am thinking of buying a commercial plasma which is alot cheaper than the consumer ones but therefore doesnt have a tuner.
    Can anyone confirm that because i have comcast i do not need a tuner.
    TIA
  2. Mort Corey
    Mort Corey Supporting Actor
    Nov 21, 2003
    981
    If you're getting a cable BOX (vs just plain Jane cable) you'll be set. With just standard cable I think you'd have to run it through a VCR or the like.
    Mort
  3. Allan Jayne
    Allan Jayne Cinematographer
    Nov 1, 1998
    2,404
    Depends on what model cable box you get. Cable and satellite TV boxes with video jacks and audio jacks in back do not need a tuner inside the TV. Cable and satellite boxes whose only output to the TV is an antenna coax jack will either need a TV with a built in tuner or need a VCR to go between the cable box and the TV.
    Video hints:
