Bryan G
Grip
- May 6, 2002
Sorry if this is the incorrect forum, but did not see one where this clearly fit.
I read on another forum that HDTV signals are carried in the standard off air package that is about $9 a month, both analog NTSC and HD signals.
This is the quote from a forum member in Chicago area.
"Comcast is currently sending 8-VSB HD broadcast feeds over analog cable. A digital cable box would have to be bypassed in order for a OTA tuner to recieve the HD signal from the cable."
I know that if you call Comcast they will tell you, you have to be at the digital service level and purchase their set top to receive HDTV. That may be true for higher tier level services that may be scrambled like Basic service ESPNHD or Subscription service HBOHD.
I don't have cable, so can't try this test.
Can someone that has an integrated QAM/ATSC tuner and Comcast HDTV cable try connecting the coax straight into their DTV input and scan for channels and see what HD channels you can get? I would appreciate it greatly and be interested in knowing what you come up with.
Bryan
Bryan
