Keith Hancock
Grip
- Nov 25, 2003
Hello,
After living with the annoying audio level deference between HD/SD channels I decided to split the signals to my Display(Sony KV-40XBR800)... SD signals direct to the Display and HD only thru the Set-top box..The SD channels look a lot better now.
My question? Is this normal and why?
Keith
Keith
