1. The HTF Tapatalk application has been discontinued. Please see the thread in the Forum Help & Feedback area for more information.
Combining Silver Sensor with VHF antenna
Discussion in 'Archived Threads 2001-2004' started by Chris S, Feb 25, 2001.
  1. Chris S
    Chris S Cinematographer
    Apr 9, 2000
    2,538
    9
    Chris S
    I have been looking at getting a Silver Sensor antenna since I have heard such great reviews about it's ability to handle multipath issues. However there is one problem. I will also need to recieve VHF signals (SS is UHF only) in order to get the ABC affiliate. So my question is, is there a way to combine a VHF and the SS into one cable? I have a Dish 6000 and I only want to run one cable to the system, but I need a way to combine the UHF and VHF antennas. I was thinking I could probably use a switch but I'm so lazy I really don't want to have to get up everytime to switch between the two. [​IMG] Any suggestions? Thanks, Chris
    Home Theater: http://www.ig-88.net
  2. Wendell R. Breland
    Jul 21, 1999
    21
    Wendell R. Breland
    Chris,
    For all 75 ohm connections the Channel Master Model 0549 should do this. http://206.155.192.130/pages/cjs1.htm
    The Rat Shack has a 15-1293 that does the same.
    Other combo's are available, common to have 75 ohm VHF and 300 ohm UHF. A splitter is the same as a combiner, just used in reverse.
    Wendell
    Technical Services Supervisor
    MAETV
