combining component inputs cheaply - need help
Discussion in 'Home Theater Projects' started by Pete Belknap, Oct 30, 2005.
  1. Pete Belknap
    Pete Belknap Auditioning
    Oct 29, 2005
    2
    Hi everyone,
    I'm in the beginning stages of building a home theater system for my house. Right now all I own is the HDTV, DVD, Xbox, Cable Box, and VCR. So as you might guess that's 3 devices with component outputs and only 2 component inputs on my TV.
    What's a good cheap way to combine these 3 devices into 2 inputs (possibly leaving me the option of expanding to four in the future)? I realize I could probably do this by buying a fancy home theater receiver now, but I really don't have the money. I just want an easy way so I don't have to get behind the TV every time I want to watch a DVD.
    Any suggestions?
    thanks
    Pete
  2. Wayne A. Pflughaupt
    Aug 5, 1999
    6,098
    32
    Katy, TX
    Wayne
    Where did you find a VCR with component outputs?
  3. Pete Belknap
    Oct 29, 2005
    2
    sorry, no the VCR doesn't have them. It's the Xbox, DVD, and HD Cable box
  4. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
    You need a 4:1 component video switch. Some good ones are made by Audio Authority. Radio Shack sells some inexpensive ones that are still remote controlled.
    A company called "MadCatz" sells what they claim is a HD compatible mechanical switch for about $40.
    Lots of choices.
