Color printer scanner combos
Discussion in 'Archived Threads 2001-2004' started by Ken Wagner, Feb 25, 2002.
  1. Ken Wagner
    Ken Wagner Stunt Coordinator
    Feb 21, 1999
    84
    My daughter seems to want a better color printer that can reproduce photos better. She also wants scanning capabilities so she can send photos via email. Anyone researched something like this or know where I can go to research myself? Price is something to keep in mind since she is in college. Personally, I normally don't like combo anything but it would save desk space. Thanks.
  2. Brett DiMichele
    Brett DiMichele Producer
    Sep 30, 2001
    3,181
    This is the route I am going.. I already have a relatively new
    Lexmark Z51 that is nothing short of phenominal on pictures
    at 1200x1200 DPI..
    For "all in one" IMHO the best on the market is the Lexmark
    X73 and X83 both are essentialy the same product but the
    X83 prints at 12PPM where as the 73 does 9 PPM..
    The X73 retails for $149.00 and the X83 retails for $199.00
    They both Print, Scan,Copy and Fax both scan at 42Bit at
    600x1200 DPI Optical and both print at 2400x2400 DPI..
  3. Ken Wagner
    Feb 21, 1999
    84
    Thanks for the advice Brett. I was afraid no one would answer when it got moved from After Hours. I've been to the computer section a while back and no one seemed to be here. I will be checking out the ones you mentioned. Sounds like they are reasonable in price. It's hard to believe they make such good printers for so little money. Thanks.
  4. Darren Lewis
    Darren Lewis Supporting Actor
    Jul 17, 2000
    534
    I use a HP OfficeJet G85. It's not the cheapest in the range but it is fantastic. It's got colour scanner and copier, colour printer and even built in fax facility.
    I bought a HP Print server cheap off ebay so I could connect it to my LAN (the G95 is identical to the G85 except that it comes with the JetDirect and duplex copy module which are optional extras on the G85).
    HP also make lower spec OfficeJets which may suit your budget better.
