Color difference vs. color stream?
Discussion in 'Archived Threads 2001-2004' started by Jason Handy, Oct 10, 2001.
  1. Jason Handy
    Jason Handy Second Unit
    Oct 3, 2001
    379
    Hi all,
    This might be a newbie question, but I simply need it answered...I just got my Toshiba 50H81 today, and I was trying to hook up component video input from my DVD (which is 2 years old), but it looks terrible. Then I noticed that the letter designations are different between the DVD and my TV. The DVD has Y,Cr,Cb while the TV has Y,Yb,Yr. Are there any cables out there that can compensate for this? Thanks for any suggestions.
  2. Jim Ferguson
    Jim Ferguson Stunt Coordinator
    Sep 9, 1998
    83
    They are the same thing (for cable connection purposes):
    Y=Y
    Cr=Pr
    Cb=Pb
  3. Jason Handy
    Oct 3, 2001
    379
    There must be a problem then, because when I connect the DVD to the TV, everything has a strong blue hue. Perhaps there is some subtle difference?
    And, the colors look fine with S-Video, but I would much rather have the component video [​IMG]
    Jason
  4. Rich Allen
    Rich Allen Second Unit
    Feb 8, 1999
    382
    110
    Salisbury MD
    Rich Allen
    Sounds like it could be a bad cable. You might want to try another set of component video cables.
  5. StaceyS
    StaceyS Stunt Coordinator
    Feb 11, 2000
    180
    Jason, which DVD player? Some DVD players can only output one signal at a time because they share some of the DAC channels. Do you have an option in your DVD player or a switch on the back to select between S-Video and component?
  6. PaulKH
    PaulKH Second Unit
    Oct 3, 2001
    413
    Jason - try using the cables on different output/inputs, to see if you get a different color problem. If so, it's a bad cable (happens).
  7. Jason Handy
    Oct 3, 2001
    379
    Thanks for the tips everybody. My DVD player is the famed Apex 600A, the one that had the factory protections removed. The DVD has both S-video and Y-Cr-Cb. There is no switch on the back, but the manual says to have only one connected at a time. When I switched the cables around, the blue screen turned red, which agrees with the bad cable hypothesis. Thank you everybody for your help - I am new to this, and it seems almost unreal how polite, civil, and eager to help people are.
    I am off to get my Monster Cable and set this thing to rest once and for all. Thanks again
    Jason
