Coaxial to Optical adapter?
Discussion in 'Archived Threads 2001-2004' started by Mike S., Dec 29, 2002.
  1. Mike S.
    Mike S. Auditioning
    May 23, 1999
    14
    I have recently added digital cable to my A/V setup.
    They offer 5.1 Dolby Digital on certain HBO and PPV movies, but my Sony receiver only has 1 coaxial input, which is being used by my DVD player.
    Is there such thing as a converter or adapter, so I can connect the Coaxial Digital Audio out to the Optical Digital Audio in on my receiver?
    If so, where can I find one?
    Mike S.
  2. Andrew S
    Andrew S Stunt Coordinator
    Sep 30, 2001
    214
    If your dvd player has an optical output, could you not use the optical input on your receiver for your DVD player and the coaxial for your cable? Just a thought that popped into my head.
    Andrew
  3. Mike S.
    Mike S. Auditioning
    May 23, 1999
    14
    Andrew, I thought about this, but what's weird about my Sony 30ES receiver, is that there is only one coaxial input, and it's only labeled DVD/LD player. So, if I hooked my cable into this, the receiver would read DVD/LD when I wanted to watch cable.
    Is there a way to change what's on the display?
  4. Nick A. G.
    Nick A. G. Auditioning
    Dec 12, 2002
    8
    Most Sony ES surround receivers I've seen have reassignable digital inputs. Consult the manual that came with your unit to see if you can do this or not.
  5. Mike S.
    Mike S. Auditioning
    May 23, 1999
    14
    Anyone have an ES model? I moved recently and can't find my manual.
    I just want to know if you can reassign digital inputs. Why they only put one coaxial digital input I don't know.
    Thanks.
