Howard_S
- Nov 1, 2001
Okay. I'm pretty to having decided what I want so I'm onto cables now. Since all the sound comes from the Coaxial cable should I spend the money on something really good? I use AR pro series coaxial cable right now and I was thinking of getting something from brands like MIT. What do you think guys? I am a firm believer that cables make a difference so I am not out to discuss whether really cheaply shielded cables will be as good as decent ones from AR for example. My question is whether the high end coaxial cables are worth getting as opposed to Ultralinks or AR cables that are reasonably priced and of reasonable quality.
