Coax or Optical audio output for DVD?
Discussion in 'Archived Threads 2001-2004' started by Marc Go, Aug 29, 2001.
  1. Marc Go
    Marc Go Agent
    Aug 6, 2001
    31
    This is an interesting debate. I currently have an Optical connection to my Pioneer DVD player, but there is also a Coax hookup. Which do you prefer and why?
    Thanks.
  2. Mike LS
    Mike LS Supporting Actor
    Jun 29, 2000
    838
    I think a search (done at off-peak hours of course [​IMG]) will reveal more than one multi-page debate on this subject. No need to get into it again.
  3. Marc Go
    Marc Go Agent
    Aug 6, 2001
    31
    I tried the search before posting...the site said that it was unavailable.
  4. Chip E
    Chip E Screenwriter
    Nov 25, 2000
    1,165
    Go digital coax if at all possible... Less fragle connection than an optical cable. IMO.
    - Chip
  5. Saurav
    Saurav Cinematographer
    Feb 15, 2001
    2,174
    In your case, the coax, because that gives you something new to mess around with, and we all know that's what this hobby is truly about [​IMG]
  6. Mike LS
    Jun 29, 2000
    838
  7. Brian Dobbs
    Brian Dobbs Ambassador
    Jul 1, 2001
    1,070
    196
    1,610
    Maryland
    Brian Dobbs
    Neither Coax or Optical has a quality advantage over the other. Coax, however, is less fragile. Go with Coax.
  8. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
    I've used both and cannot hear a difference. Right now I am using optical for my DSS receivers, and coaxial for my DVD player.
    Home Theater magazine did a blind-test a year or so ago.
    All the coax cables (cheap->expensive) sounded about the same.
    But the reviewers all heard a difference with some of the optical cables. This was never explained, but my pet theory was that some of the optical cables had been damaged when they were wound tight and stuffed into a blister-package.
    Because a 75 ohm video cable is cheap/common/robust, this is the usual recommended cable.
  9. Lee Bailey
    Lee Bailey Second Unit
    Jun 8, 2000
    263
    Central California
    Lee Bailey
  10. Barry_B_B
    Barry_B_B Second Unit
    May 14, 2001
    453
    Barry
    I use coax mainly because I read the optical connections are not always the most secure. I have to apply some real force to get the coax cable off.
