Coax Digital loudness versus Optical Digital
Discussion in 'AV Receivers' started by Chuck Watwood, Jun 21, 2003.
  1. Chuck Watwood
    Chuck Watwood Stunt Coordinator
    Dec 9, 2002
    122
    After reading that coax digital was equal if not superior to Optical digital, I went with the coax when setting up my Panny RP91. It plays at a much louder level than my optical out of my other Panny RP62 player. I have had to back way down on the volume with the coax. Is this just a benefit from the coax?
  2. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    it just sounds like the gain is higher. i don't see it as a benefit or a liability. just the way it is.
  3. StephenL
    StephenL Second Unit
    Nov 21, 2000
    341
    The type of cable, coaxial or optical, has no effect on the volume level of a digital signal. Any difference in volume level is a result of processing at the source or, most likely, by your receiver/processor, not the type of cable.
  4. Leon Liew
    Leon Liew Stunt Coordinator
    Oct 23, 2001
    234
    I always prefer coax to optical cables since my inception
    towards HT. I felt that coax is more solid sounding than
    optical which sounds 'hollow' but others may beg to defer.
  5. Michael Reuben
    Michael Reuben Studio Mogul
    Feb 12, 1998
    21,763
    3
    5,110
