close to finishing sub.....
Discussion in 'Home Theater Projects' started by Cam McFarland, Jun 23, 2004.
  1. Cam McFarland
    Cam McFarland Supporting Actor
    Feb 6, 2004
    699
    What is best way to ensure that spade type connections
    WONT come off of speaker tabs?
    Besides soldering........
    TIA
    - Cam
  2. Cam McFarland
    Feb 6, 2004
    699
    TIA
    - Cam
  3. Rory Buszka
    Rory Buszka Supporting Actor
    Jun 5, 2002
    784
    They should stay on all right. If not, take the 'spade' connector off of the 'lug' on the speaker and squash it flatter. Not too hard, but just so that those pieces that are curled over will provide more resistance to the spade slipping.
  4. Rory Buszka
    Jun 5, 2002
    784
  5. minhG
    minhG Stunt Coordinator
    May 6, 2004
    82
    if you're using a shiva or tempest, i assume you've got some female spades that match the speaker? the ones I got from radio shack needed to be 'squashed' as Rory describes, after that they stay on no problem.
  6. minhG
    May 6, 2004
    82
  7. Patrick Sun
    Patrick Sun Moderator
    Jun 30, 1999
    38,749
    480
    9,110
    Use a pair of pliers to squash the curled female spade connectors to ensure a tight fit, leaving just enough for the male spade connector to fit snugly.
  8. Patrick Sun
    Jun 30, 1999
    38,749
    480
    9,110
  9. Cam McFarland
    Feb 6, 2004
    699
    Great...thanks alot, the guy I bought the Tempest from
    built me a wiring harness for it, but I just wanted to
    be sure they will not come off.
  10. Cam McFarland
    Feb 6, 2004
    699
  11. RodN
    RodN Stunt Coordinator
    May 9, 2004
    58
    If you really really really want to be 100% sure you know what to do, you mentioned it already.
  12. RodN
    May 9, 2004
    58
  13. Cam McFarland
    Feb 6, 2004
    699
    Yea...I figured as much, but having never tried it before
    I wanted to make sure I would not ruin the speaker....lol
    Might not be a bad thing to learn though, huh....
  14. Cam McFarland
    Feb 6, 2004
    699
