Robert Barker
- Oct 22, 2000
After connecting an Acurus A125x5 as external amplification for my Onkyo 777 over the weekend I now get erratic clicking / popping from all speakers. When this occurs it comes from all speakers at the same time. It is really noticeable when pulling up the channel guide for Direct TV and scrolling through the channel. Each channel brings a very faint click, or pop. When watching TV and not turning the channel the clicking / popping is not present, or I just don't notice it.
I have also noticed this when watching movies through the DVD Player. I watched two movies ( Pearl Harbor / Behind Enemy Lines) over the weekend to push the amp and noticed the clicking / popping in quite seens. It is very erratic. I thought it was the Direct TV Receiver causing this so I turned it off w/ no luck. I thought it could be the DVD Player, so I turned it off and the cliking was still there. Even w/ the two sources off I still got this very faint clicking. Why? Could it be the voltage coming through the Direct TV RG6 cable causing this?
I have tried to isolate the Speaker, power and video cables from each other as much as possible with no luck.
My Setup consists of the following...
Amplifier: Acurus A125x5
Pre/Pro: Onkyo 777
DVD Player: Panasonic Progressive Scan (Toslink only output)
RPTV: Toshiba 50H81
Satellite: Direct TV Hughes Receiver
Speakers...
Mains: Polk Audio RT 800i's
Center: Polk CS400i
Rears: Def Tech's
Speaker Cable: Monster
Interconnects between Onkyo and Amp: Acoustic Research Pro Series HT130's.
I'm using a Belkin power center to power the TV, DVD Player, VCR and Satellite Receiver.
For Trouble shooting purposes I have purchased another Belkin Surge Protector for only the Receiver and Amplifier.
I have the Receiver and Amplifier connected to a Craftsman Auto Switch shown
here.
Both of the surge protectors are running off the same 15 amp circuit.
Keep in mind that this clicking has no pattern to it and can only be reproduced when changing channels in the Direct TV channel guide.
Any Ideas? Please help. Its driving me nuts trying to find the source. Any trouble shooting steps would be great.
Thank you,
Robert Barker
Austin TX
Pre/Pro: Onkyo 777
RPTV: Toshiba 50H81
Speakers...
Center: Polk CS400i
Rears: Def Tech's
here.
Thank you,
Robert Barker
Austin TX
