clearing info from the start/run command (1 Viewer)
Ted Lee
hey all -
in xp, do you know if it's possible to clear the info in the start/run command?
i mistyped some telnet commands and now they're sitting there...driving me crazy.
thx!
Gerald LaFrance
Earth
Gerald LaFrance
this should do the trick:
Start/ Control Panel/ Appearence & themes/ Taskbar & Start menu/ Start
Menu/ customise/ advanced; then click on clear list. that will wipe out all in run. :D
not sure if there is another way to do it but that will work!!
Staff online
Schoening32
