Drew R
- Mar 22, 2001
- Drew Ressler
Any place where I can buy Clear DVD Double Amaray cases? (i.e. the ones used in Project A-Ko and Grave Of The Fireflies)
InetDVD is still the choice if you are looking for colored keepcases.Jeff's correct about this.
But it appears www.usplastic.com has 'em all beat, price-wise! (And they show 2-disc Amarays as In-Stock. And these babies are harder to come across than a pro-P&S HTF member!)
I find the disc spins a bit on the hub.Then that would be just like the "spinning" action which we get with most Amarays. (Which, I suppose, is actually a GOOD thing, since the data side of the disc is more or less suspended in mid-air, free from contact.)
But, I myself prefer the "alternate" (or Type 2) kind of Amarays the best. These hold the disc tighter (but not overly so), so that it doesn't spin around at will while handling the case; thus making the disc's artwork readable each time box is opened. Anal? Yep, guess so. But that's the fate of an HTF member.
