You should use a specific formulation for the pinch rollers. Alcohol can dry them out. If you don't use the deck much, it probably doesn't need demagnetized. But also if you don't use the deck much, alcohol is probably OK for the rollers anyway.
The easy way? One of those cleaning tapes does an OK job too. Depends on how thorough you want to be.
