Cleaning scuff marks on rubber surrounds...
Discussion in 'Home Theater Projects' started by Eric Eash, Jan 28, 2004.
  1. Eric Eash
    Eric Eash Second Unit
    Aug 3, 2003
    367
    after all the handling of my av15s, the rubber surrounds look pretty beat up. what do you guys use to clean the surrounds if anything? will it hurt to use a rubber cleaning agent on them? thanks in advance.
    eric
  2. Jack*Mains
    Jack*Mains Stunt Coordinator
    Sep 25, 2002
    156
    Whatever works.
    I usually have a bottle of windwex sitting around that I use - works pretty well.
    Othersie, just about any cleaning agent should be fine.
    I used acetone a few time to get permanent marks off a rubber surround. Not sure if I recomend this, but it -has- worked.
  3. George W
    George W Stunt Coordinator
    May 25, 2001
    91
    water has always worked fine for me, but I usually only use it for removing mdf dust.
  4. Hank Frankenberg
    Hank Frankenberg Cinematographer
    Oct 13, 1998
    2,573
    Try a little Armor-All.
  5. Ken Cline
    Ken Cline Stunt Coordinator
    Jun 30, 1997
    99
    Boy I wouldn't. IMO Armour All deteriorates rubber. I also heard about this years ago, but don't remember where.
  6. Ken Cline
    Jun 30, 1997
    99
  7. Eric Eash
    Aug 3, 2003
    367
    i was actually wondering about armour all, and then after wiping off the excess oil with a clean rag. i think i'll try some water and some windex first, i'll hold off on the armour all.
    eric
