Cleaning Paradigm Atoms
Discussion in 'Archived Threads 2001-2004' started by Keith Mickunas, Dec 28, 2001.
  1. Keith Mickunas
    Keith Mickunas Cinematographer
    Dec 15, 1998
    2,041
    My mom has a pair of white Paradigm Atom speakers and got something all over the speaker grill. I think she had a plant on top of it and overfilled it. Anyways, I've looked at the speaker and can't determine if the grill comes off or not. I've pulled on it some, but its either permanently attached or a very tight fit and I don't want to break it. Anybody have any suggestions on how to clean the grill off?
  2. RossVTaylor
    RossVTaylor Extra
    Feb 4, 2001
    19
    Keith,
    I can't comment on whether or not the grills are removable, but I've had incredibly good luck with Spot Shot carpet cleaner (I buy it in a two-pack at Costco). It's also safe as a laundry pre-cleaner and it's removed almost every kind of stain from every kind of fabric, without damaging the fabric. Since you don't have to rinse it out, it should work well on the speaker grills.
    Good luck,
    Ross
  3. Mike_A
    Mike_A Stunt Coordinator
    Oct 7, 2001
    153
    i'm pretty sure those are not removable from what i've read. ross's suggestion sounds like it would work and i'd probably take a vaccuum cleaner to it too
  4. Philip J
    Philip J Auditioning
    Dec 21, 2001
    7
    gotta pair, and the grills are not removable.
  5. Keith Mickunas
    Dec 15, 1998
    2,041
    Thanks for the info guys. I'll tell her to try the stain remover.
