Jin E
- Nov 19, 2000
I have a couple of old Kenwood Amps (from the 70's) that need some contact cleaning. They have developed some scratchyness then adjusting tone controls/ volume/ etc. This will be the first time I've done anything like this... so if you guys have any advice (spray techniques, brands, etc) I'd really appreciate it. My plan is to pop open the case and just go to town with the spray-type cleaner 9Radio Shack Part Number 64-4320). Any advice would be greatly appreciated! (Check out the amps below... and in links in my sig)
-Jin
My Theater
-Jin
My Theater
