MikeHU
- May 6, 2004
Thanks to the web masters and all those contributing. I've been snooping for a while now, and appreciate all your hard work and knowledge re HT. (ok, enough brown-nosing). I have a 55" Mits. w/ HD built-in. I've used Avia to attempt to calibrate to the best of my limited abilities. Picture looked great for past 1 1/2 yrs., but now is looking a little fuzzy or pixalated. I use Comcast HD cable. I've never had the lens cleaned or the set professionally calibrated. Am I overdue for a lens cleaning? Could that be causing the lack of sharpness?
Can I clean them myself (anyone with how-to instructions?)?
Local seller charges 100 for a lens cleaning. Would I be better off just having the set professionally calibrated (and would that include cleaning the lens?) How much does that typically cost? Looking for some tweaking advise. Thanks.
Dennon AVR 1801
Klipsch (love em) RB-35's, RC-35, RS-35's
Paradigm sub
etc, etc,
Dennon AVR 1801
Paradigm sub
etc, etc,
