Cleaning Inside Projection TV
Griffey
Duane
I have a Toshiba 50A50 projection set that has to last me another 6 months or so (waiting for next years tax return to get a new one). Anyway, the lens, mirrors and inside the screen need to be cleaned in the worst way. I wanted to ask if there is a best method for opening up the set before I do anything stupid. Does the screen up front come off or do I open it from the back? What should I use to clean it? Any help would be appreciated.
Griffey
Duane
Thanks Doug. Now if I can just figure out how to get the screen off of my set. It has a one piece frame and I sure don't want to damage it trying to get it off.
Kirb-dog
