Citizen Kane Disc 2 Audio "pops" during documentary
Discussion in 'Archived Threads 2001-2004' started by rob kilbride, Sep 28, 2001.
  1. rob kilbride
    rob kilbride Supporting Actor
    Mar 12, 2001
    728
    Rob Kilbride
    Watching "The Battle Over Citizen Kane", I noticed at least two major audio "pops". One was at 3:05 into the first chapter the second was at 3:52 into the final 11th chapter. The second one is accompanied by some diagonal lines across the picture. I was concerned before I watched the documentary because I noticed the disc was scratched from behind very slightly on the outer edge of the disc. Can someone tell me if these discs all have these pops or if my disc is damaged? Also I'm not familiar with what part of the disc is read first, does it start from the outside and work in and work inside out after the layer switch or vice versa. And are scratches on the backside of a disc that penetrate the metal more serious that an exact same size scratch on the front plastic? Any help is greatly aprprectiated.
  2. Richard Kim
    Richard Kim Producer
    Jan 29, 2001
    4,385
    I also heard pops when watching the documentary so it's not just you.
  3. Peter Kline
    Peter Kline Cinematographer
    Feb 9, 1999
    2,393
    DVD's and CD's are read from the inside out. Didn't notice the pops on my disc.
  4. SteveRS
    SteveRS Stunt Coordinator
    Apr 8, 1999
    149
    Yes there are a couple of low-level pops.
    Sounds like someone bouncing a ball on my exterior stucco walls.
  5. Oswald Pascual
    Oswald Pascual Second Unit
    Jun 30, 1997
    299
  6. Dwayne
    Dwayne Supporting Actor
    Jan 22, 2000
    760
    5
    Ditto on Oswald's ditto.
    -Dwayne
  7. rob kilbride
    Mar 12, 2001
    728
    Rob Kilbride
    Thanks for the feedback. I forgot to mention that the diagonal lines that occur during the audio pop in chapter 11 do not appear when I pause the movie and use the dvd step buttons. Any explaination for this? I thought for sure this was a video tape artifact but I don't understand why it doesn't show up when I go frame to frame.
