Dimitri v C
Grip
- Apr 29, 2002
Hi,
what do you think of this marriage ??
many thanks
many thanks
Your room acoustics is going to affect the brightness of the sound significantly more than any amp. Get the system you want and tune the room appropriately...
I would suggest that unless you are an extreme "far field" listener, that is you listen a long way away from your speakers, there is no room treatment that can cure a dry, brittle or bright high end from a speaker/amp combo.
Unless you are running a "reflecting" system like BOSE 901s any direct sound from your speaker will be as the amp/speaker marriage sent it.
The only thing the room treatments can do to the resonances and relfections is affect the "reflected" sound. They cannot change the direct sound which is what the ear/brain usually hears (precedence effect).
John Casler
Neither the speaker or amp has a hump in it's higher frequency response. How do you account for the supposed 'bright' sound?
I don't account for it because I have never heard it. A room cannot create additional high frequency energy.
It can only interact with it. All reflected sound is deteriorating sound, with high frequencies decaying and being absorbed quite rapidly.
