Cinema Filter in onkyo/integra
Discussion in 'AV Receivers' started by Babek, Mar 15, 2004.
  1. Babek
    Babek Stunt Coordinator
    Jan 1, 2003
    87
    Hi, if you have an onkyo or integra receiver, are you using the cinema filter option? I'm not too clear on what it does, but can someone please clarify it for me. Also, are you using it?
    thanks
  2. PaulDA
    PaulDA Cinematographer
    Feb 9, 2004
    2,700
    99
    4,110
    St. Hubert, Quebec, Canada
    Paul
    Cinema Filter is similar to Cinema Re-EQ in THX receivers. Its purpose is to soften some of the high frequencies that can sound too aggressive or "bright" on sources that were mixed for a much larger soundstage (like a large movie theatre). I have an Integra 6.4 so it has the THX version, but the purposes are the same. My (limited) experience with it so far is that is helps some DVDs, and is unnecessary for others. I have found it to be very source dependant.
    Hope this helps.
  3. Babek
    Jan 1, 2003
    87
    thanks for the reply
    Does this mean you have your cinema filter on? I turned it on for the first time yesterday, and I guess it did help with minimizing the screeches and high pitched stuff.
  4. PaulDA
    Feb 9, 2004
    2,700
    99
    4,110
    Paul
    I turn it on or off depending on the DVD or TV programme.
  5. Kernel X
    Kernel X Extra
    Feb 26, 2004
    24
    Yes, if the DVD is recorded in THX I will use the cinema eq setting, which is it's intention. It cuts out a lot of the harshness you get from the front channels. Great receiver...Ken
