Chronic Hiccups!! Help!!!
Discussion in 'Archived Threads 2001-2004' started by Scott Weinberg, Jan 23, 2002.
  1. Scott Weinberg
    Scott Weinberg Lead Actor
    Oct 3, 2000
    7,477
    I'm serious! It's now 4:30 in the morning. I've had the hiccups off and on since about 3PM. It's freaky!
    Does anyone know what causes the hiccups to hang around for 13 hours?
    And does anyone know any effective ways of curing this annoying malady?
    Th--hic---anks!
  2. Jon_B
    Jon_B Screenwriter
    Nov 27, 2000
    1,025
    The only thing that works for me is holding my breath. I usually hold it until I can't hold it any longer, then I take a deep breath and hold it again. Repeat until hiccups are gone.
    Good luck.
    Jon
  3. Tony_Faville
    Tony_Faville Supporting Actor
    Jun 1, 2000
    519
    Try this one..... take a glass of water, throw a straw in it, then drink from the straw while plugging your ears. Yes, you look goofy but yes, it works.
    However, chronic hiccups can also be signs of a more serious issue.
  4. McPaul
    McPaul Screenwriter
    Apr 1, 1999
    1,795
    50
    Vancouver
    Paul M
    BOOOOOO!!!!!!!!!!!!
    did it work Scott?
  5. Rain
    Rain Producer
    Mar 21, 2001
    5,015
    Scott, if you are hiccupping for that long, I'd go see a doctor.
  6. John Spencer
    John Spencer Supporting Actor
    Mar 2, 2000
    857
    Just picture Gailard Sartain naked. Your throat should constrict to the point that hiccups are an impossibility.
    *Suggestor not responsible for bouts of nausea or depression
  7. Scott Hayes
    Scott Hayes Second Unit
    Oct 2, 2001
    357
    I am 6ft 2in tall 320lbs lots of tatoos naked covered head to toe in vaseline and I save my urine.
    Feel better?[​IMG]
  8. Scooter
    Scooter Screenwriter
    Sep 3, 1998
    1,505
    10
    DFW Area Texas
    Scooter
    This not only always works for me..but EVERYONE I have taught it to.
    Works best with someone with you..but you can do this on your own. Tell yourself or who is with you the EXACT moment you are about to hiccup again. As if trying to predict it the INSTANT it is going to happen. 99 times out of a 100...this works. However...for as long as you have been doing this..I would see a doctor.
  9. Mark Dubbelboer
    Mark Dubbelboer Screenwriter
    Oct 6, 1999
    1,008
    psst....want to know a secret?
    hiccups are just in your head.
    seriously, ever wonder why different "miracle cures" work for different people. It's because they believe it's going to work on them. As long as you keep your mind occupied on the hiccups they will go away. Usually i'll just repeat the word hiccup to myself for about 30seconds after the first one comes out and they'll be gone.
    I can't remember hiccuping more than twice since doing that
  10. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
    i've got a slight variation on tony's:
    1. take a glass. fill it with water
    2. (this may be hard to describe) - take the glass, hold it with your middle and ring fingers of each hand.
    3. while attempting to drink from the glass, use your thumbs and plug your ears.
    4. drink away...you don't have to drink a lot. for me, just a gulp or two does the trick[/list=1]
      my friend showed me this once. i thought she was crazy...until i tried it for myself. since then it's worked every time for me.
  11. KyleS
    KyleS Screenwriter
    Jul 24, 2000
    1,232
    One thing to try would be eating a spoonful of sugar. Dont just swallow the sugar but stick it in your mouth on your toungue then swallow. Almost a guaranteed fix [​IMG] Seriously
    KyleS
  12. John Thomas
    John Thomas Cinematographer
    Mar 23, 2000
    2,633
    Get 2-100 watt bulbs and screw them into a lamp/whatever and leave 'em on for 2-3 hours. Take 'em out and insert them into your eye sockets. It kicks those hiccups' ass every time. [​IMG]
  13. Todd Christ
    Todd Christ Stunt Coordinator
    Nov 11, 2001
    231
    this ALWAYS works for me and everyone who has tried it...
    it takes two people, so find a friend or family member
    • get a glass of water, about 6-10 oz. will do
    • the person with the hiccups simply puts their hands in the air (like a TOUCHDOWN signal in football)
    • the other person holds the glass while the hiccup infested person drinks from the cup...
    • you have to finish the whole glass of water
    • the helper is allowed to pour as fast as you can drink - without spilling - and laughing is allowed, i think it actually helps the process [​IMG]
    honestly, it works everytime...!
    good luck! and Happy New Year!
  14. Nathan*W
    Nathan*W Screenwriter
    Sep 9, 2001
    1,076
    2
    Nathan
    My remedy is silly, so I'm lothe to repeat it here, but it works. (and no, it hasn't already been mentioned)
  15. Bruce Berti
    Bruce Berti Stunt Coordinator
    Jan 31, 2001
    202
    This has worked for me EVERY time:
    Take a glass of water and tilt your head so you are arched over a sink. Take the glass of water and start drinking it(with your head almost upside down) over the sink so that the water, instead of first hitting your tongue is actually initially making contact with the roof of your mouth so that the water runs down the exact opposite side of your throat. Sorry if I'm not describing it well, but it definitely works. Good luck
  16. Chris Knox
    Chris Knox Stunt Coordinator
    Aug 10, 1999
    154
    Scooter was the closest to the ACTUAL remedy. Here are the facts:
    Hiccups are digestive aides. A hiccup occurs in order to aide in the digestion of food as it is actually your diaphragm contracting at odd intervals in order to help crush the food in your body that you didn't chew well enough when you ate it. Other things cause this to happen, but typically it is to aide in digestion.
    The trick is that a hiccup is caused by an electrical pulse sent by the part of your brain that also is used for concentrating. If you are concentrating on the hiccup it may never go away. When you begin to concentrate on something else the pulses are interupted and your hiccups go away. The more you worry about your hiccups, the longer they'll will stay.
    When I come across someone who has them I begin by asking them a series of questions that stimulte their thoughts and concentration. Here is an example:
    When is the last time you saw a bunny rabbit?
    What color was he?
    Where did you see him and what time of day was it?
    Was his tail a different color?
    And on and on...
    The last question I usually ask is, "Do you still have your hiccups?" This triggers a deeper concentration and usually provokes them to wait for the next one that never comes. This actually assists in supressing the hiccups because it interupts the electrical pulses that power them.
    Of couse this won't work on you now that you know how it works. Read a book or take a test. Distract yourself...
  17. Morgan Jolley
    Morgan Jolley Lead Actor
    Oct 16, 2000
    8,721
    115
    I saw on the X Show a few years ago that a remedy for hiccups was to rub an ice cube on your throat. I haven't gotten the hiccups in a while, so I never really tested this out.
    They also said to put toothpaste on a mosquito bite because it disinfects and soothes.
  18. Steve Christou
    Steve Christou Long Member
    Apr 25, 2000
    15,709
    381
    Manchester, England
    Steve Christou
    Sit cross-legged, than lift one leg behind your head, than the other, and than move about the room on your hands, than after a while stop and just swing your body to and fro while in this position, it feels great don't it? Like a chimpanzee. This also works as an interesting new lovemaking position, which I don't think is in the Kama Sutra, so I've just discovered a new position, woohoo!![​IMG]
    As for curing your hiccups Scott, the best way for me is holding my breath, or drinking a glass of water might do, good luck![​IMG]
  19. Philip_G
    Philip_G Producer
    Nov 13, 2000
    5,030
    one sure-fire way (similar to the ear thing..) is to take a deep breath, hold it, and plug your nose while slowly sipping a glass of water until you can't anymore. The sensation of drowning is supposed to help..
  20. Chris Knox
    Aug 10, 1999
    154
    That's for sissys! Just tie yourself to a few cinder blocks and toss them over your nearest bridge. The sensation of drowning is much more realistic and I guarantee you the hiccups will go away! [​IMG]
