Chroma Bug Question?
Discussion in 'Archived Threads 2001-2004' started by Pablo Abularach, Jul 15, 2002.
  1. Pablo Abularach
    Pablo Abularach Supporting Actor
    May 27, 2002
    526
    Does the chroma bug affects normal TVs as it does the HDTV progresive scans, or if you have a Normal TV and you use an interlaced conection between the DVD and TV you wont be affected by the chroma bug
    Pablo Abularach
  2. Dmitry
    Dmitry Supporting Actor
    Nov 30, 1998
    740
    Pablo,
    while the chroma bug is very apparent on my Sony DVP-700P in progressive mode I don't notice it in interlaced mode. I think it's progressive mode only.
  3. Allan Jayne
    Allan Jayne Cinematographer
    Nov 1, 1998
    2,404
    As far as I know, if the player has the chroma bug it will show up in interlaced mode as well as progressive. During interlaced scanning the odd scan lines fade as the even lines are being drawn, and vice versa, so the chroma bug is less noticeable.
    If you are using the interlaced output of the DVD player but going into a progressive scan TV, the better TV doublers treat the chroma bug affected areas as subject motion and will do interpolation which hides the chroma bug.
    More:
    http://members.aol.com/ajaynejr/vidbug2.htm
