Bobby_M
- Aug 11, 2003
After reading a great article on AVS regarding this subject, I'm wondering if you PJ owners can make a quick case for the native format you chose. Actually, perhaps a better question is, was the native format one of the deciding factors for you or was it secondary.
For example, based on user praise of the Pan 300U, it's the first PJ i'm going to consider. I AM slightly concerned that my satellite TV usage will be compromised. Currently on my 50" RPTV I view about 60% 4:3 and 40% widescreen DVD. I may be getting into dishnetwork HDTV sometime in a year or two so that may increase my widescreen usage. However, if I build a dedicated theater room, my shift might actually go to 80% widescreen usage because I'd be less likely to go down the basement for a TV show.
I suppose the major plus to using a 4:3 PJ and screen is when you go to mask. Masking a 4:3 to any widescreen format should only require horizontal masking correct?
Finally, if you were to pick a 4:3 PJ as the closest in value and image quality to the Panasonic 300u, which would it be? Thanks.
Bobby
Bobby
