Chimney infinite baffle
Discussion in 'Home Theater Projects' started by Mike Nep, Jul 28, 2003.
  1. Mike Nep
    Mike Nep Stunt Coordinator
    Apr 12, 2002
    93
    As I sit bored at work, I am wondering if it would be possible to mount a subwoofer (or multiple) in your chimney that would act as an infinite baffle? When you think about it, your chimney is better braced than any enclosure would ever be and the air requirements well, are pretty much infinite. Now I'm not saying I'd try this by any means. I'm just wondering if this would conceptually work. Any takers?
  2. Jake K
    Jake K Stunt Coordinator
    May 22, 2003
    132
    It would radiate the neighborhood with bass, which some people might not like too much.
  3. JoeFish
    JoeFish Stunt Coordinator
    Jul 3, 2003
    67
    Santa would be pissed.
  4. TimForman
    TimForman Supporting Actor
    Dec 4, 2002
    847
    Seal the top of the chimney, otherwise you have a TL (unless you want to stuff your chimney with PolyFil). Calculate the air space of the chimney. You need a minimum of 4 times the Vas of the driver, 10x is optimum. Should work. I don't think the driver cares what shape the air space is. And you'd better hope you don't have a creosote build-up.
  5. Kyle Richardson
    Kyle Richardson Screenwriter
    Jan 1, 1998
    1,073
    Should work if sealed up. Just remember not to use the fireplace [​IMG]
  6. Mike Nep
    Apr 12, 2002
    93
    Tempting, but highly doubtful.[​IMG]
  7. Jeff Meininger
    Jeff Meininger Second Unit
    Jun 5, 2002
    481
    AFAIK, most fireplaces in '90s homes lead up to thin, flimsy metal pipe. I think.
  8. Jack Gilvey
    Jack Gilvey Producer
    Mar 13, 1999
    4,948
    You guys are just putting a damper on it.
  9. ThomasW
    ThomasW Cinematographer
    Nov 6, 1999
    2,282
    Given the shape and size of most flues you'll have a TL not an IB.
  10. Henry_W
    Henry_W Stunt Coordinator
    May 7, 2002
    137
    Jack - I may be the only one that really smiled at your groaner, thanks for the grin...
  11. TimForman
    Dec 4, 2002
    847
    This is almost as bad as Brett's pop can speaker idea. That was Brett wasn't it?
  12. Kyle Richardson
    Jan 1, 1998
    1,073
  13. TimForman
    Dec 4, 2002
    847
    I'm going for the Pringles mini-TL.
  14. Mike Nep
    Apr 12, 2002
    93
    I didn't say it was a good idea, just a bored at work thought. Believe me, I've come up with worse.
  15. Kyle Richardson
    Jan 1, 1998
    1,073
    We know but its fun to theorize how well or poorly it would perform. [​IMG]
  16. Jack Gilvey
    Mar 13, 1999
    4,948
  17. Hank Frankenberg
    Hank Frankenberg Cinematographer
    Oct 13, 1998
    2,573
    Jack, I smiled too, but your humility is more impressive[​IMG]
  18. Javier_Huerta
    Javier_Huerta Supporting Actor
    Mar 9, 2002
    619
