Dan Pawlowski
- Aug 12, 2002
What do you think of the 281's midrange and treble quality compared to the Missions?I think the Kit281s are excellent stand alone speakers. They blow Mission speakers away in all aspects.
The treble quality improved slightly when I added the felt to the baffle on the kit281. A very simple and cheap "tweeak" worth trying IMO. I used a spray adhesive normally used for mounting photographs to attach the felt. Makes it semi-permanent and easy to remove in case i didnt like the sound.
One would think(at least i thought) that the mid-range for the kit281 would suck if you look at the freq. response graph of the AV8. But I think Adire did a great job with their crossovers EQ-ing the peak at 2.2kc out.
I would like to see some ts parameters on the AV5 driver Adire uses though if anyone has them.
later
Dan
