Cheap Pre/Amp setup
Discussion in 'AV Receivers' started by TyreeS, Apr 15, 2004.
  1. TyreeS
    TyreeS Agent
    Jun 16, 2003
    27
    i'm looking at getting a pre/amp setup but dont have the big budget that i would like to. can anyone suggest something around $700 that will work.
    i was looking at the Pioneer 914k w/ a carver av505 what do you guys think?
  2. ChadLB
    ChadLB Screenwriter
    May 5, 2002
    1,523
    That would work fine. I have a Pioneer 811 and a Parasound HCA855a. I might recommend the parasound over the Carver but that is just my opinion. So you could buy a Pioneer 812/814/912/914 and a 5 channel amp.
  3. TyreeS
    TyreeS Agent
    Jun 16, 2003
    27
    thx for the repsonse. why do u like the parasound better?
  4. ChadLB
    ChadLB Screenwriter
    May 5, 2002
    1,523
    I have not heard a carver in a while so the parasound has grown on me....that is all.
  5. JasonBrandon
    JasonBrandon Agent
    Feb 23, 2004
    46
    what are the xover settings for the 914?
  6. ChadLB
    ChadLB Screenwriter
    May 5, 2002
    1,523
    Most likely 100hz is the lowest it will go. I still don't understand why pioneer doesn't have them go down to 80hz. I think almost all other entry level receivers do that.
    Personally I don't like the looke of the new Pioneers either.
    It looks like they have decent dacs and the MCACC setup though.
  7. Wayne Ernst
    Wayne Ernst Cinematographer
    Feb 24, 2002
    2,588
  8. TyreeS
    TyreeS Agent
    Jun 16, 2003
    27
    so are their better options that still fall into my budget?
  9. ChadLB
    ChadLB Screenwriter
    May 5, 2002
    1,523
    We are not saying it is a bad option it is just that the pioneer crossover is lowest a 100hz.
    A couple other options would be a HK230 or used HK 325, Onkyo 701s go cheap now, Not sure what Yammies have pre-outs as I have not kept up with the Yammies that much.
    Basically with HK's you get triple crossover meaning you can set the crossover point for front, center and rear speaekers (not sure of the range). I think with yammies and onkyo's they go as low as 80hz.
    The pioneer will probably due great with a amp. They use dual
    motorola chips.
    I had problems with Drop outs on my Onkyo 600 and I hear nothing but problems with the HK units though I still might
    test out a HK 230 or one of the other ones.
    Also note the Onkyo 600/601 doesn't have pre-outs.
    They all seem to have something negative about them.
  10. Mike SJ
    Mike SJ Supporting Actor
    Nov 10, 2003
    718
  11. TyreeS
    TyreeS Agent
    Jun 16, 2003
    27
    i want a setup that offers all the surround sound formats available. is there a setup to be had that does DVI switching also?
    i know you guys have options plz chime in
  12. ChadLB
    ChadLB Screenwriter
    May 5, 2002
    1,523
    I don't think any entry level receiver will have DVI Switching. I think you will have to spend some big bucks to get that....
  13. Drew_W
    Drew_W Screenwriter
    Jul 2, 2003
    1,718
    Why do you need a cheap separates setup? Why not just get a good receiver for that price?
  14. TyreeS
    TyreeS Agent
    Jun 16, 2003
    27
    i can agree with that can you give me some suggestions in that same price range that can outperform or match that setup?
    thank you
  15. Drew_W
    Drew_W Screenwriter
    Jul 2, 2003
    1,718
    audiogon. Look for receivers from Marantz, Denon, Pioneer Elite...maybe even an Arcam AVR200 if you're lucky...the Rotel RSX-1055 might be a bit of a stretch, but it's worth a shot...
