Cheap Bathroom Speakers
Discussion in 'Speakers' started by Tommy_N, Jan 21, 2004.
  1. Tommy_N
    Tommy_N Stunt Coordinator
    Jul 5, 2002
    131
    Hello all,
    I'd like to run 1-2 speakers into my bathroom. Sound quality is not that important, although I would like it to sound better than the cheap radio I have now. (that shouldn't be too hard [​IMG]
    The one reason I want to use a speaker powered by my receiver is so that someone would be able to listen to TV/Movies while using the bathroom.
    I guess it needs to be water-proof. I would also like something small. In-wall is not an option since this is for an apartment.
    Any suggestions?
    Tom
  2. JohnnyN
    JohnnyN Stunt Coordinator
    Sep 10, 2001
    228
    upgrade and retire your HTiB to the bathroom.
  3. Kenneth Harden
    Kenneth Harden Screenwriter
    May 13, 2002
    1,365
    Look at Radioshack or Parts Express for cheap indoor/outdoor speakers. They are somewhat cheap and weatherproof.
  4. Tim Streagle
    Tim Streagle Stunt Coordinator
    Sep 1, 2003
    65
    Go to ebay or some such site and look for Advent Calypso's(discontinued or Out of business). $50/pr. and they are moisture resistant. They sound like really good $50 speakers.
  5. Jim Rakowiecki
    Jim Rakowiecki Stunt Coordinator
    Sep 2, 2003
    162
    I found these onthe radio shack web site.
    http://www.radioshack.com/product.as...5Fid=40%2D5041
    Ya know while your running wires you could very easily pull a video cable in as well and run a small monitor.
    You would probably need a video amp but I think radio shack has those also.
    Just a thought.
    Since this is an apartment have you considered wireless?
  6. Jon_Welker
    Jon_Welker Second Unit
    Apr 29, 2003
    404
    I have a great in-bathroom sub...[​IMG]
  7. CalvinCarr
    CalvinCarr Supporting Actor
    Dec 4, 2003
    512
    Get some wireless outdoor speakers from Best Buy.
  8. Tommy_N
    Jul 5, 2002
    131
    Thanks for all the suggestions.
    Of course now thanks to Jim, I'm debating about adding a small monitor. (Bad enough that when the weather is this cold I barely leave the house, besides going to work. Now I won't even leave the bathroom [​IMG] )
    Wireless would probably work really well. I'm not too concerned about sound quality. Then in a couple years when I buy I place I can use them outside.
    thanks again
    Tom
  9. Mike Wilk
    Mike Wilk Stunt Coordinator
    Jun 12, 2003
    84
    I have a pair that look like this Radio Shack set -
    White RCA® 50-Watt, 2-Way Die-Cast Mini-Speaker (Each)
    $39.99 Brand: RCA
    Catalog #: 40-5002 Model: PRO-X44AV
    I don't think I paid that much but I've had them probably 10 or 12 years in the bathroom. So far, the stream from showers, etc hasn't hurt them nor have the several times they've been knocked to the floor. They weigh upwards 5 lbs a piece.
    YMMV
