cheap answer to big screen home theater? (1 Viewer)
Myo K
http://www.i-glassesstore.com/iglasses-hrv.html
i was thinking about picking this up, i seriously think itd be interesting ot sit back turn up the home theater speakers and put these suckers on and immerse yourself into the movie,
this can be a somewhat affordable way to watch movies on a simulated big screen eh? not only that itll block out any distractive elements.
anyone ever try this i glasses before?
Jack Briggs
I've seen these things mentioned in the A/V magazines, but never tested. And if headphones can seem a bit confining at times, no telling about these "iGlasses."
What's that saying? "If it sounds too good to be true ..."
Greg_R
Portland, OR
Greg
I've used similar products (Sony Glasstron, etc.) with VR applications. It takes a good bit of tweaking to get a crisp image. For extreme space limitations these may be a good idea...
Ronn.W
I won a Philips Scuba set a few years ago. Basically the exact same thing, but much larger, heavier and clunkier. I would get a decent picture with it, but it was not the same as watching it on a big screen, it was the same as watching it on a small screen, an inch or so away from the eyeball.
I assume the newer technology helps a lot with weight and quality, but from my previous experience these would only be good for airplanes and the like. I don't think you could watch movies on it regularly, and I don't think you'd want to.
Greg_R
Portland, OR
Greg
For our applications it looked like a 50-60" TV (we weren't using a hi-res source). On higher res or film sources (which I haven't tried) the image may be degraded. Size does become a factor after while (viewer fatigue)...
acinstallation172
