Cheap and Great Long Component Cables for Projector
Discussion in 'Archived Threads 2001-2004' started by Bruce Cadotte, Feb 24, 2002.
  1. Bruce Cadotte
    Bruce Cadotte Stunt Coordinator
    Dec 21, 2001
    98
    10
    After testing and using my new projector on a table in front of the screen(about 10-11 feet away)i decided to
    mount it to the ceiling.
    i needed about 25 feet of component cables from the DVD Player to the Projector vs. the 12 feet of "Better Cables"
    Component Cables i was using when the Projector was on the floor.
    Not wanting to spend a lot of money right now(wife wants a new car) i went to Radio Shack to see what they have,while looking for 3 cheap Yellow RCA video Cables(they did not have any longer then 12 feet in stock)a got a idea looking at their RG-6U Quad Shielding Coax Cable at $19.99 for 25 Feet and 6 Coax to RCA adapter for $1.50 ea. why not use this until i am ready to spend a lot of money for long component cables from "Better Cables".
    i hooked it up and marking each cable with colored tape
    and WOW in a good way,i had JP 3 in the DVD Player
    from before and it looked so much better,with no changes to the settings just placement,so total about $80.00
    vs how many hundreds from "Better Cable".
  2. Matt Stryker
    Matt Stryker Screenwriter
    Oct 12, 2000
    1,307
    Bruce- I've used RG-6 with screw in RCA ends for subwoofer cable before, and it is a great way to get quality sound over moderate distance.
    You might also try http://www.a2zcables.com ; they usually have good prices on good quality cables.
  3. Kevin Coleman
    Kevin Coleman Second Unit
    Jul 3, 1999
    495
    Bruce,
    As long as everything you used (especially the F-Connectors and RCA adapters) is 75 OHM you will be in good shape. In fact they will probably look just as good as the "Better Cables"
    Kevin C. [​IMG]
