Charter Digital Cable Volume
Discussion in 'Playback Devices' started by wally, Aug 4, 2003.
  1. wally
    wally Second Unit
    Feb 12, 2001
    473
    Over the last few weeks I’ve noticed a great volume disparity between many of my channels. When switching from a comfortable listening level on i.e., Discovery or a network channel to one of the HBOs, I can hardly hear the HBO. This occurs on all my sets and we haven’t added set top boxes or anything lately, it just happened.
    Any ideas or experience similar?
    I live in St. Charles, MO just outside St. Louis.
  2. Mark Hedges
    Mark Hedges Second Unit
    Mar 21, 2003
    442
    I think what is happening is that when you switch from an analog to a digital channel the volume level goes down. My cable box outputs a much quieter signal from digital channels than analog - something like 15db less volume.
    If your cable box has a digital out and you run that to your reciever the volume levels are more consistant.
    Mark
  3. wally
    wally Second Unit
    Feb 12, 2001
    473
    Thanks Mark,
    I received a response from Charter stating that the volume should stay level across channels.
    I have more faith in your response [​IMG]
    Between this problem, and what seems like a rate increase every month, I'm moving closer and closer bringin' on the dish!
  4. Sean_R_N
    Sean_R_N Auditioning
    Dec 28, 2002
    10
    Make sure your box is setup for "Heavy Compression" in your audio options.
  5. Lewis Besze
    Lewis Besze Producer
    Jul 28, 1999
    3,134
    I have Charter here in CA but I haven't experinced this at your level,however I don't channel surf I pretty much record shows to my Replay Tv and watch it later.I don't know if that makes any difference though.
