Lyle_E
- Nov 21, 2003
Ok after parking here for a few weeks and enjoying my lil home theater (setup before i discovered HTF™) I have viewed so many great HT setups. budget prevents upgrades to equipment at this time.
So I am going to undertake a budget transformation to the current look. it is a small room that I have already altered to slide the rptv and components into the wall.
First opinion:
The color of the room (a mistake on my part
) it is currently a dark brown (ok ok not a good choice but I was going for darkness) What colors would you suggest if it were your room? something that is easy to look at yet keep light reflection down. I am obviously not good with colors......
Front - home.earthlink.net/~elwe/hometheatre/dsc00010.jpg
Back - home.earthlink.net/~elwe/hometheatre/dsc00008.jpg
The door is installed now.. and trim will be added soon
I want to add sconces with a dimmer to change the lighting eventually.
Just fishing for some ideas folks
Oh and budget means as cheap as I can get it done
First opinion:
