Manuel Delaflor
- May 25, 2001
I can't buy an Adire driver over the internet unless I want to pay around 60% more due to taxes and shipping. Im searching for an inexpensive yet good driver to begin a DIY proyect and I found the HED12 for about 85 bucks, I know it is not a Shiva, but I managed to get this specs. Are they any good for home use? Thanks!
__________________
10" unit:
sensitivity ( 2.8V@1m ) 88
Power Handling RMS 150 Watts
Nominal Impedance 4 ohms
Voice Coil dia. 1 1/2½
Mounting dia. 228mm
Mountind depth 118mm
Spkr.Displacement 1.30 liters
Fs 24 Hz
qts 0.617
qms 13.600
qes 0.646
vas 80.61 liters
Xmax +/- 12.0 mm
Revc 3.6 ohms
____________________
12" unit:
voice coil diameter : 2½
speaker displacement : 1.98 liters
FS: 22 Hz
Qts : 0.355
Qms : 12.880
qes : 0.365
Vas : 176.22 liters
Xmax 17 mm
Revc 3.6 ohms
____________________________________
That's all I found, hope is enough.
__________________
10" unit:
Mounting dia. 228mm
Fs 24 Hz
qts 0.617
qms 13.600
qes 0.646
vas 80.61 liters
Xmax +/- 12.0 mm
Revc 3.6 ohms
12" unit:
FS: 22 Hz
Qts : 0.355
Qms : 12.880
qes : 0.365
Vas : 176.22 liters
Xmax 17 mm
Revc 3.6 ohms
