center speaker to go with boston CR8s (1 Viewer)
AmericanIdiot
Dave Haag
Since the CRs are not made anymore, what model boston center would match these mains? Something equal to the CR2?
Joseph DeMartino
Florida
Joseph DeMartino
Your best bet would be to contact Boston Accoustics. They can tell you exactly which current speakers best match your CRs. (If none of their current speakers are timbre-matched, they can tell you that, too, and suggest the correct used speaker you'd need to look for.)
Joe
aotorusxwxr
