Center Speaker: Sensitivity Hi or Low
Discussion in 'Archived Threads 2001-2004' started by Norman L, Apr 19, 2002.
  1. Norman L
    Norman L Second Unit
    Feb 19, 2002
    261
    What are the advantages or disadvantages of Center speakers that are 87dB, 91dB, or 93dB.
    Should that make a difference in sound clarity?
    I have an 80watt per channel amp 6.1.
  2. Harold_C
    Harold_C Stunt Coordinator
    Apr 1, 2002
    198
    The efficiency of a loudspeaker has nothing to do with the way a speaker sounds. It is simply a measure of how loud it will play with a 1 watt input and a test signal.
    In general, the better loudspeakers tend to fall into the same efficiency range, but so do some truly dreadful speakers.
    The best center channel speaker is the one that is identical to your front speakers. The second best center channel speaker is one that is designed to match your front speakers.
