center speaker position
Discussion in 'Speakers' started by sam_sark, Jul 22, 2003.
  1. sam_sark
    sam_sark Extra
    Jul 5, 2003
    20
    is it ok to keep the center speaker ( i have b&w lcr60) in the tv cabinet below the tv or is it a bad idea since the speaker would be covered on both sides (don't know if that is a problem!) ....
  2. Vincent_S
    Vincent_S Second Unit
    Nov 29, 2002
    450
    I used to do that and it was fine. I think it is important to keep it at ear level when you are sitting.
  3. David Preston
    David Preston Supporting Actor
    Mar 23, 2003
    698
    From what I have seen a lot of people put there center on top of their tv. If your tv is to high you might want to give it a downward angle. There is somekind of bracket you can put it on to be on top of your tv. If you are interested you can do a search I have seen it not sure where.
