Center Speaker Popping
Discussion in 'Archived Threads 2001-2004' started by James Daniels, Aug 22, 2002.
  1. James Daniels
    James Daniels Auditioning
    Apr 19, 2002
    6
    [​IMG] Can anyone help? My Cerwin Vega center speaker sometimes pops when I play music but it will not pop when I watch movies or TV. I really pops when I play Hip-Hop. I will take any suggestions. Thanks for your help.
  2. Chris Tsutsui
    Chris Tsutsui Screenwriter
    Feb 1, 2002
    1,865
    I'd check the wires and connections first.
    Then see if some type of other electrical device is being turned on in the house the same time the popping occurs. Whenever I flip a light switch or turn on a fan, I can hear popping from my sub as well.
    Maybe place it in a corner where it can get more output and turn down the volume so you can use less power.
  3. Angelo_Petralba
    Angelo_Petralba Second Unit
    Jan 22, 2002
    366
    If you set it to SMALL this might help. Also turn te volume down (Calibrate)
  4. John F. Palacio
    John F. Palacio Supporting Actor
    Jan 6, 2002
    575
    "I really pops when I play Hip-Hop"
    Don't play Hip-Hop! [​IMG]
    But honestly folks.... sounds like you're bottoming out your woofer!
