Center speaker behind the screen.
Discussion in 'Speakers' started by Norris, Jul 17, 2005.
  1. Norris
    Norris Stunt Coordinator
    Jul 14, 2002
    201
    Will the screen be blocking the sound enough to affect quality? The screen material is obviously much thicker than the fabric grill used on the speaker itself.
  2. Wayne A. Pflughaupt
    Aug 5, 1999
    6,099
    33
    Katy, TX
    Wayne
    Yes, you’ll lose high frequencies. Screens are typically perforated to allow some high frequencies to pass. But even then you’ll need to electronically boost the highs to make up for the loss.
    Wayne A. Pflughaupt
  3. Norris
    Jul 14, 2002
    201
    Do you mean turning up the treble? Also, where do you guys put your center speaker? Behind or in front of the screen, top or bottom?
  4. John Garcia
    Jun 24, 1999
    11,571
    24
    NorCal
    You might look into an acoustically transparent screen. They're out there though they may not be inexpensive.
  5. Mark Seaton
    Mark Seaton Supporting Actor
    Oct 10, 1999
    599
    Mark Seaton
    To place a speaker behind a screen, you need to use a screen intended for this application. The costs can vary greatly ranging from some of the lesser knowns to Stewart MicroPerf all the way to Screen Research's solution. The impact on the sound is less with the MicroPerf and most especially with the Screen Research, but others offer good quality 'perf screens as well. In many rooms the placement differences of the L/R vs. the center make for equal or more variation than that of the screen. While it does have some effect on the picture, placing the center channel behind the screen (ideally at 1/2-2/3rds height), usually makes for a much more convincing and engaging presentation.
  6. Leo Kerr
    Leo Kerr Screenwriter
    May 10, 1999
    1,698
    Some DIY screens are fairly nicely acoustically transparent..
    I'm using a light gray cotton screen, stretched, with a loose black terry backer (about an inch off of the back) as a light trap. Very minimal impact on the sound - at least, I've got far worse problems that any impact caused by the screen are going to be so minimal as to not exist...
    Leo
