Center Channel Upgrade?
Discussion in 'Archived Threads 2001-2004' started by Steven Tyner, Dec 24, 2001.
  1. Steven Tyner
    Steven Tyner Auditioning
    May 26, 1999
    13
    I have the Infinity CC3 center speaker and was wondering if it was worth it to upgrade to the Infinity IL-36C.I have Infinity Overture 2 as my mains.Any info would be helpful.Thanks,Steven.
  2. Mike boettner
    Mike boettner Stunt Coordinator
    Dec 1, 2001
    229
    what are the specs on the cc3?
  3. Steven Tyner
    May 26, 1999
    13
    Mike, the CC3 is a 2-way,150 watt,dual 5-1/4",1"(25mm)tweeter
    frequency response:80hz - 20lhz
    Sensitivity:91db
    I hope this helps you.Thanks again,Steven.
  4. Mike boettner
    Dec 1, 2001
    229
    do the woofers have poly cones, and what is the tweeter made out of?
    btw do the overtures have metal cones?
  5. Steven Tyner
    May 26, 1999
    13
    Mike,I think the woofers are poly cones.I don't know what the tweeter is made of and no the overtures do not have metal cones.Thanks,Steven.
  6. Mike boettner
    Dec 1, 2001
    229
    im just asking all these questions because the il-36c would be alot better then the cc3, but it might not blend with your mains well, unless you wanted to upgrade those as well
  7. Steven Tyner
    May 26, 1999
    13
    Mike,thanks for your help.I'm going to buy it from my local CC and see for myself.If it does not sound right its going back.Thanks,Steven. "Go Maryland"
  8. Mike boettner
    Dec 1, 2001
    229
    i hate to say it but that is the worst CC i have ever been in!!
    btw its a 3 way center channel, very cool. it just might sound better than your mains
