Center channel speaker help (1 Viewer)
Cowboy Jack
Erik
Need some help. I bought Martin Logan in-ceiling speakers for my theater system. Problem is that the center channel speaker (an ML-67i) requires roughly a 10.5" opening and I discovered I have only 8" horizontally between cross members in my ceiling. Everything is installed except the center channel--discovered the issue too late. Any suggestions on an in-ceiling center channel speaker that would fit my 8" space and pair with the Martin Logan's already installed. IThanks!
Dave Upton
Audiophile
Houston, TX
Dave Upton
The ML-62i is probably your best bet given the size of the space you have to work with.
Larsenv
