Chris S
- Apr 9, 2000
- Chris S
Well I just finished upgrading my speakers by purchasing a Paradigm CC-370 which now sits on top of my Toshiba TW40X81 and I am a bit concerned. The speaker weights 25 lbs. and I am worried that the top of the set might begin to buckle under the added weight. I would move it out in front of the set (on a speaker stand or something) but I don't have enough room. Has anyone else had a large speaker on top of their set and did it do any damage? Also is there anything that I might be able to do to spread the weight out across the set? Chris
Home Theater: http://www.ig-88.net
