Patrick Sun
- Jun 30, 1999
If I needed to transfer a bunch of speed dial numbers stored in a Nokia cell phone, what product would you recommend to me (please provide weblinks if possible).
I have a product called "Fonesync" that we have used with the Nokia 6160 cell phone (it's only compatible with the newer Nokia 5165 cell phone), and it had a data cable with the right data connector for the cell phone, and a 9-pin serial port connector on the other end to connect with a PC. Fonesync is now defunct.
Now, we have quite a few different Nokia cell phone models, and we have some people that need to migrate those speed dial numbers (some folks have over 100 numbers saved) to a new cell phone model, current Nokia models we use: 8260, 3360, 5165, and the 6360.
So, any ideas?
So, any ideas?
