Ceiling speakers to match Adire Kit281s/LCC
Discussion in 'Archived Threads 2001-2004' started by Rob Lloyd, Sep 24, 2002.
  1. Rob Lloyd
    Rob Lloyd Stunt Coordinator
    Mar 22, 2001
    234
    I don't have room to mount kit81s as surround speakers for my Adire Kit281s & LCC. So I'm looking to match some ceiling speakers to the fronts that will blend in.
    I'm thinking the ones w/ aim-able tweeters would be best so I can direct the tweets towards the seating positions.
    Preferably under $250/pr.
    Rob
  2. Shawn Solar
    Shawn Solar Supporting Actor
    May 12, 2001
    763
    Not sure what speakers to buy but you should look for speakers with similar tweeter and woofer material and also similar crossover points for a best match. Also make sure you can wire to the speakers beforehand.
